Tue Apr 10, 2012 12:05 pm
Hi
I have issue with my Vagabond Mini.
Now when i power up my Einstein.
The unit is on but the indicator that's suppose to be green stays red.
The modeling light cannot be turned on also.
I had tried to power the Einstein with another vagabond unit and it is ok.
I had tried to switch the battery pack with another vagabond unit, turns out it is the
vagabond itself and not battery which has problems.
i tried to power a fan and iphone charging and it works.
Can i know what's the problem?
Tue Apr 10, 2012 5:08 pm
It sounds like an internal fault with the inverter. You should contact the distributor from whom you made the purchase for warranty service.
Users browsing this forum: Majestic-12 [Bot] and 36 guests
