First, the "Ch1" on the CyberSync is a radio frequency, while the Metz is likely an optical setting. Even if it is radio, "Ch 1" is an arbitray number on both systems, and are not intercompatabile. If the Metz has a basic slave function, set it (likely how you got the SB800 to work, using the Nikon term SU-4 mode). Lacking this feature, a simple optical slave can be purchased through FlashZebra.com which will fire it. This method assumes the Metz can see the other flashes fire. Alternatively, you can get a Cyber Sync reciever for it and have it triggered the same way as the B800 (an inexpensive adapter may also be required). Keep in mind, while the Cyber Syncs do work for most flash units, some are not compatabile (this can differ even within the same manufacturer). We have not tested any Metz flashes, and cannot guarantee they will work, though they likely will. In the event they do not, you do have 60 days to return them.
