| E640 modeling ligt woont stay off. http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3538 |
| Author: | edgerider [ Thu May 10, 2012 5:16 am ] |
| Post subject: | E640 modeling ligt woont stay off. |
HI there ! no matter what i try, with TT5 and PMC2 if i go on TLmode the modeling light keeps going on no matter what i do. this is very annoying..... in classic channel no problem. I have tried just about every setting and i finally removed the bulb. but i can ear that the powering of modeling light is still active and drawing power from the VLM. even if i manually turn the model light to "OFF", next time i press the trigger it will just turn back on. i have tried ALL the settings on the TT5 regarding modeling light and so... What do I have to do to have the model light remain on "OFF" position ????? |
| Author: | Technical Support [ Thu May 10, 2012 9:32 am ] |
| Post subject: | Re: E640 modeling ligt woont stay off. |
There is a setting in your transmitter that allows control of the model lamp from the flash head. You will need to contact PocketWizard for specifics. |
