| Transmitter Not Plugging Into My Rebel T2i http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3539 |
| Author: | djohnst4 [ Fri May 11, 2012 11:39 am ] |
| Post subject: | Transmitter Not Plugging Into My Rebel T2i |
I'm having issues with the size of the chord that goes from my transmitter to my Rebel T2i. The part that plugs into the camera body is too big and does not fit. Do I have to buy another chord? :?: |
| Author: | Technical Support [ Fri May 11, 2012 12:53 pm ] |
| Post subject: | Re: Transmitter Not Plugging Into My Rebel T2i |
The cable supplied with the Commander a 10" long 2.5mm male mono plug to pc. Is there a reason the CC is not mounted to the hot shoe? If the cable is not the one stated above please call customer service. 800 443 5542 or local 383 3982. |
| Author: | Technical Support [ Fri May 11, 2012 1:50 pm ] |
Also, the transmitter and cyber commander should slide into the hotshoe without the need for a cord. However, the rebel series cameras do not have a PC terminal, and a hotshoe adapter would be required for you to be able to use a PC cord (the style included with the lights an transmitter). |
| Author: | PowerEngineer [ Fri May 11, 2012 2:31 pm ] |
Technical Support wrote: Also, the transmitter and cyber commander should slide into the hotshoe without the need for a cord. However, the rebel series cameras do have a PC terminal, and a hotshoe adapter would be required for you to be able to use a PC cord (the style included with the lights an transmitter). I think you mean, "rebel series cameras do NOT have a PC terminal"... |
| Author: | Technical Support [ Fri May 11, 2012 5:41 pm ] |
Sorry, its fixed. Moderating via my phone while on the road. |
| Author: | PowerEngineer [ Sat May 12, 2012 6:39 am ] |
Typos happen (especially with me) :P I just added that so folks who read this thread later on don't get confused. |
