 [ 10 posts ]
Sat Jan 07, 2012 9:11 am
Just got my Cyber Commander and supplies with a couple Einsteins for Christmas and very impressed with the whole system. I already had a couple AB800 and AB400's. I noticed one peculiarity in regards to modeling lamps and wonder if I am missing something or this is just the "old technology meets new technology" snag.
Test system:
2 Einsteins and one AB800. Cyber Commander. CSR+ on AB800.
When I work with groups in the CC Bracket Flash mode, I notice that the AB800 modeling lamp comes on full power if not selected in the group. If it is in the selected group it behaves as expected. The Einsteins always behave as expected whether in group or not. Once I leave the groups the AB800 returns to normal. I also notice that if I put the AB800 in Standby mode on the CC the modeling light goes full on as well, instead of off.
Is this just something to live with or did I miss something in configuring the system? I have three CSR+ receivers and all behave the same with the AB800.
Thanks for any help,
Stuart
Sun Jan 08, 2012 10:35 am
This will probably require a replacement reciver. I would suggest calling and talking to Joe on Monday (I won't be in unitil at least Tuesday).
Sun Jan 08, 2012 1:20 pm
TS: Stuart states he has three CST+ receivers, so scratch the "This will probably require a replacement reciver"
I agree with contacting Joe (Tech Help)
Mon Jan 09, 2012 10:24 am
Thanks guys, I will give him a call.
Stuart
Wed Jan 11, 2012 6:21 pm
Thanks again for the quick help guys, Joe was able to get it all resolved and I am looking forward to my first shoot with my new Einsteins and Cyber Commander next week!
Sun Mar 04, 2012 6:45 pm
So.....what was the problem and solution? I have a similar prob.
Thanks,
Randy
Sun Mar 04, 2012 8:52 pm
This is a symptom that is difficult to diagnose via text based communications. I strongly recommend giving us a call tomorrow (or whenever is best).
Tue May 15, 2012 9:24 pm
Guess I need to call as my AB800 is exhibiting similar behavior.
Tue May 15, 2012 10:10 pm
Probably best. It is most likely a settings issue, real time walk through is pretty simple, though.
Thu May 17, 2012 9:41 am
Replacement receiver is on it's way. The modeling light kept getting brighter on standby - it only worked properly for about 4 minutes then the modeling light would turn on and slowly get brighter. Turning the CSRB+ to standby again didn't do anything, turning it on set the light to where it should be, turning it to standby set it back to the brightness level it was slowly creeping up at.
Powering everything off and disconnecting overnight would reset the behavior - but again standby would only work for about 4 minutes.
I should probably swap the AB800 out for an E640 while I still have 60days just to keep everything the same.
 [ 10 posts ]
