| AB Speedring for Photoflex 800SC Starlite? http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3554 |
| Author: | Freerojo [ Thu May 24, 2012 4:12 pm ] |
| Post subject: | AB Speedring for Photoflex 800SC Starlite? |
Hi, just set up my newly purchased AB's. I have a Photoflex Starlite softbox that I would like to use with the AB. The Photoflex Speedring says "800SC". Is there anyway I can adapt this so an AB can hold on to it? Hope this is clear, thank you, Ron |
| Author: | Technical Support [ Thu May 24, 2012 4:59 pm ] |
| Post subject: | Re: AB Speedring for Photoflex 800SC Starlite? |
Most speedrings have a center adapter that is interchangable. You may want to contact Photoflex to see if they have an adapter for WhiteLightning/AlienBees/Balcar. Also, our LGSR fits most Photoflex 4 and 8 rib softboxes. The image I find for the speedring you referenced has holes in odd places. If your box's rods only go in the corners, our speedring should work. If it requires the holes that are on the edges, then it probably won't. |
