Sun May 27, 2012 10:02 am
I have recently purchased a cyber commander with a csxcv and csrb+. My flashes don't trigger the FIRST shot if:
I am in the main control window and the window is active
They will fire if I hit the flash button on CC then use the camera
They will fire first shot if I wait until the main window goes off
Is this normal? Thanks!
Tue May 29, 2012 3:45 pm
This is the first I have seen this, but it appears to be normal. I have tested on all the past incarnations of firmware and on different units. I don't think this has been reported as usually, a metering or power adjustment will be performed prior to an atempt to trigger.
I will, however, bring this up to engineering.
Users browsing this forum: No registered users and 40 guests
