CC Question
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3558
Author:  Jomax [ Sun May 27, 2012 10:02 am ]
Post subject:  CC Question
I have recently purchased a cyber commander with a csxcv and csrb+. My flashes don't trigger the FIRST shot if:
I am in the main control window and the window is active
They will fire if I hit the flash button on CC then use the camera
They will fire first shot if I wait until the main window goes off
Is this normal? Thanks!
Author:  Technical Support [ Tue May 29, 2012 3:45 pm ]
Post subject:  Re: CC Question
This is the first I have seen this, but it appears to be normal. I have tested on all the past incarnations of firmware and on different units. I don't think this has been reported as usually, a metering or power adjustment will be performed prior to an atempt to trigger.
I will, however, bring this up to engineering.
