| Which Anderson powerpoles on Vagabond mini http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3582 |
| Author: | jbradford [ Mon Jun 18, 2012 6:45 pm ] |
| Post subject: | Which Anderson powerpoles on Vagabond mini |
Hi, I wanted to buy some extra Anderson powerpole connectors so that I could run my Einstein off of a 50 ah 12V deep cycle battery. I was hoping you could specify which of the Anderson powerpole connectors is used on the Vagabond mini (e.g., part number or model name) and perhaps recommend a place to purchase them. Thanks Jonny |
| Author: | Technical Support [ Tue Jun 19, 2012 10:29 am ] |
| Post subject: | Re: Which Anderson powerpoles on Vagabond mini |
PP15/45 series commectors. The links for the components you need are below. There may be other outlets through which you can order them. Also, there is a specialized crimp tool that is required (or highly recommended) to attach them. We reccomend 12-14AWG wires, and run as short of a wire as possible. http://www.powerwerx.com/anderson-power ... using.html http://www.powerwerx.com/anderson-power ... tacts.html http://www.powerwerx.com/anderson-power ... -pins.html |
| Author: | jbradford [ Tue Jun 19, 2012 1:20 pm ] |
Thanks for the prompt reply. |
| Author: | jbradford [ Tue Jun 19, 2012 1:27 pm ] |
Technical Support wrote: PP15/45 series commectors. The links for the components you need are below. There may be other outlets through which you can order them. Also, there is a specialized crimp tool that is required (or highly recommended) to attach them. We reccomend 12-14AWG wires, and run as short of a wire as possible. Wow, the crimp tool I found on the site is >$200. Does PCB sell replacement cables for the Vagabond or charger that would already have the powerpoles crimped on? Thanks. |
| Author: | Technical Support [ Tue Jun 19, 2012 1:55 pm ] |
No, we do no not. However, I have seen crimp tools in the $30 range and cheaper. Also, you can visit this link for ready made or ready to alter cables: http://www.powerwerx.com/adapter-cables/ |
