Sync jack / plug for older WL10000?
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3587
Author:  stevecon [ Fri Jun 22, 2012 1:19 pm ]
Post subject:  Sync jack / plug for older WL10000?
I have a couple of the WL10000 "coffee cans" I did not get sync cables when I bought them. I see that they have what appears to be a 1/4" headphone type jack for sync. If this is indeed the case, what plugs are used - mono (tip and ring) or stereo (tip, ring, center)?
Thanks!
Author:  Technical Support [ Fri Jun 22, 2012 3:13 pm ]
Post subject:  Re: Sync jack / plug for older WL10000?
Originally, they came with a stero end, with tip positive, ring negative, sleeve open configuration. These cords can be found here: http://www.paulcbuff.com/sc.php
These are recommended for this type of light, as a mono cord can lead to adverse effects if the AC outlet used is mis wired.
Author:  stevecon [ Fri Jun 22, 2012 3:26 pm ]
Technical Support wrote:
Originally, they came with a stero end..
Great - that's what I needed to know. Lastly, I imagine that the tip & ring associated terminals are used and there is no connection on the sleeve terminal. Would that be right? I want to use them with radio triggers, so a very short (12" or less even) cord is all I need.
Thanks again!
Steve
Author:  Technical Support [ Fri Jun 22, 2012 8:41 pm ]
Yes, the sleeve needs to be isolated from the others. The other end (for your remote) needs to be mono or a stereo connection with the ring and sleeve joined. If you use a stereo connection with, say, a MultiMax or other remote that supports AF for camera triggering, there can be issues with which contacts close.
