Thu Jul 12, 2012 8:06 pm
My Cyber Commander has been working fine for a few years. Today, however, it began to continuously reboot (displaying FW v40)...then going blank...then displaying FW v40. I've put in a fresh set of alkaline batteries, and I've reseated the microSD card (still no luv).
When I bring the CC near an Einstein, it fires in "uncontrollable" rapid succession until I pull the power cord. All in not well <g>...
What should I try next?
Stephen
Thu Jul 12, 2012 8:55 pm
Remove the SD card entirely. Does normal operation return? Also, are the batteries loose? If so, gently pry out on them so the make better contact with the batteries themselves.
Thu Jul 12, 2012 9:23 pm
Removing the SD card altogether "fixed" my problem. The CC is operating normally. Thanks.
Thu Jul 12, 2012 9:59 pm
Probably a corrupted card. You can try reformatting it (to FAT16). However, it may have been permanently damaged.
Users browsing this forum: Google [Bot] and 30 guests
