Cyber Commander continuously reboots
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3615
Author:  skahn [ Thu Jul 12, 2012 8:06 pm ]
Post subject:  Cyber Commander continuously reboots
My Cyber Commander has been working fine for a few years. Today, however, it began to continuously reboot (displaying FW v40)...then going blank...then displaying FW v40. I've put in a fresh set of alkaline batteries, and I've reseated the microSD card (still no luv).
When I bring the CC near an Einstein, it fires in "uncontrollable" rapid succession until I pull the power cord. All in not well <g>...
What should I try next?
Stephen
Author:  Technical Support [ Thu Jul 12, 2012 8:55 pm ]
Post subject:  Re: Cyber Commander continuously reboots
Remove the SD card entirely. Does normal operation return? Also, are the batteries loose? If so, gently pry out on them so the make better contact with the batteries themselves.
Author:  skahn [ Thu Jul 12, 2012 9:23 pm ]
Removing the SD card altogether "fixed" my problem. The CC is operating normally. Thanks.
Author:  Technical Support [ Thu Jul 12, 2012 9:59 pm ]
Probably a corrupted card. You can try reformatting it (to FAT16). However, it may have been permanently damaged.
