 [ 16 posts ]
Thu Jun 28, 2012 2:06 pm
I'm considering upgrading our studio from Speedotron to Einsteins. The problem is we occasionally need more power from a single source. Any suggestions for mounting several units into a single softbox?
Thu Jun 28, 2012 3:38 pm
I have seen multi head speedrings from other manufacturers. I am not sure if you need a special box to fit the necessarily larger speedring (I would imagine so). I do not recall the brand that does this, however. Alternatively, you could use two heads with smaller softboxes. I have not seen any solutions to mount two heads into one standard softbox, however, that does not mean it is not possible.
Thu Jun 28, 2012 7:26 pm
I'm pretty sure I saw a Joel Grimes video where he stuck a second light in a soft box by mounting it on a second stand and sticking it through the opening around the speedring. I'm away from my gear at the moment but will see if that'll work with an AB large box when I get home. Not sure you could do this with three lights though... not enough slack?
Thu Jun 28, 2012 7:39 pm
Thanks, but I would need to mount the set up on a single Manfrotto boom.
I was able to locate a Chimera double light rig:
http://www.adorama.com/CMDHBSA.html
It will only hold two lights but that may be enough.
Tue Jul 31, 2012 5:03 pm
Balcar used to make a 3 head "soft box" called the Balcar Galaxy Box, once in a blue moon youll see them pop up on ebay.
Pics:
http://kleinanzeigen.ebay.de/anzeigen/s ... o/u9026973
Tue Jul 31, 2012 6:12 pm
Thanks lsm!
That looks really cool and a great find. I'll be keeping my eye out for one of those
Sat Aug 04, 2012 8:47 pm
Depending on how big your softbox is, this might also work:
http://www.msegrip.com/product/hardware ... -3fer.html
Wed Aug 08, 2012 11:10 am
3 lights in a box on a boom? seems like a lot of weight to hang out there..
Wed Aug 08, 2012 3:43 pm
I'll most likely be sticking with the 2 light set up
Wed Aug 08, 2012 3:51 pm
That still seems like a good amount of weight to boom. Hope you have a sturdy stand with some counter weights.
 [ 16 posts ]
Users browsing this forum: Google [Bot] and 14 guests
