White Lightning vs. Einsteins
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3649
Author:  chadwithuhc [ Fri Aug 10, 2012 6:37 pm ]
Post subject:  White Lightning vs. Einsteins
I am curious, is there any advantage the White Lightning X1600 has over the Einstein E640's besides the extra 20ws? It seems like the Einstein is a superior flash in all aspects and only costing $60 more. I feel like I'm missing something...
Author:  Technical Support [ Fri Aug 10, 2012 9:23 pm ]
Post subject:  Re: White Lightning vs. Einsteins
The White Lightnings come with a 5 year warranty and a 7" reflector. Einstein has a 2 yr warranty and no included reflector. Otherwise, Einstein is a better flash unit in every way. If you want to add Cyber Commander, or even standard CyberSyncs, the price difference draws even closer.
Author:  chadwithuhc [ Tue Aug 14, 2012 12:39 pm ]
Even though the WS are similar, do they put out the same amount of light? I know some times there can be variations depending on reflectors and such. Also, is there any use case you would say the White Lightenings are better than the Einsteins?
Author:  Luap [ Tue Aug 14, 2012 6:54 pm ]
Honestly there is no contest unless you intend to drive a truck over them, in which case the WL wins. The only other possible advantage for the WL is it is a much less complex design, and lower complexity always results in greater overall reliability because there are fewer parts. By this standard, a Flashpoint probably has a better MTBF than a $15,000 Scoro system, though I don't have statistics.
Author:  Technical Support [ Wed Aug 15, 2012 12:10 pm ]
20Ws of light added to 640Ws is only 3% more energy. Assuming equal effeciency, that is still 1/3 of 1/10 of a stop, so they are identical in output. Any variations in reflectors would be the same, as each use the same reflector choices.
Author:  chadwithuhc [ Wed Aug 15, 2012 12:11 pm ]
Thanks for the info guys!
Author:  BigIronCruiser [ Fri Aug 17, 2012 7:01 pm ]
The WL definitely wins in two categories
1) fingers /accessory mount - large modifiers won't fall off
2) more vertical rotation with modifiers, particularly a beauty dish
