Sat Aug 18, 2012 3:09 pm
I have a few Vagabond Mini batteries and they have always worked well for me until today. One of the batteries isn't working at all. It won't take a charge and it doesn't work at all. I have tried to replace the fuse and it didn't work. I appreciate any help. They haven't been used that much at all but they have been used in the past few weeks. They are less than 1 year old.
Sat Aug 18, 2012 5:38 pm
If you have not done so, try charging just the battery, i.e. remove it from the inverter and plug the charger directly. Try both chargers.
Also, what happens if you swap batteries among the inverters? Does the problem follow the battery or the inverter?
Sat Aug 18, 2012 5:42 pm
I haven't tried to take them apart. I didn't realize it was something that could be done easily since these are the mini, not the old vagabond 2. I'll see if I can figure that out.
Sat Aug 18, 2012 6:55 pm
There is a release on the opposite end of the assembly from the AC outlets. The battery will slide out.
Users browsing this forum: Majestic-12 [Bot] and 13 guests
