Sun Aug 26, 2012 8:37 pm
Does anybody have any experience using Nikon Capture Control Pro 2 with the Einstein and PocketWizard PowerMC2 and Nikon Flex system? I am trying to utilize Nikon Capture Control Pro2 with this system and keep getting a message "The camera was not able to take a picture because the attached flash's TTL mode is not compatible. Please change to a non-TTL mode or check your manual to see which flashes can be used in TTL mode. I changed the channel on the back of the Einstein from C-TL 01 to CH 01 and made sure the transmitter is set to CH 01 but I still get the same message!
Mon Aug 27, 2012 10:01 am
We are not familar with the porduct or the issue, and therefore can offer no advise. I would recommend contacting LPA with this issue, as they are the designers, they may know what is going on. 802-658-0038 x572
However, if anyone is familiar with this, they are welcome to chime in.
Users browsing this forum: Google [Bot] and 9 guests
