Using Light Meter with CC & Einstein
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3735
Author:  DukePro [ Thu Oct 11, 2012 12:45 pm ]
Post subject:  Using Light Meter with CC & Einstein
I'm using Einstein w/ CC. Now, I want to buy a light meter from Sekonic, Please let me know which one works with CC? Thanks
Author:  DukePro [ Thu Oct 11, 2012 12:47 pm ]
Post subject:  Re: Using Light Meter with CC & Einstein
Or how can we use the CC as a light meter
Author:  Technical Support [ Thu Oct 11, 2012 3:37 pm ]
Check out pages 40-42 in the NEW CC manual. This covers the lightmeter operation. See the link below.
http://paulcbuff.com/manuals/cc.pdf
Author:  DukePro [ Thu Oct 11, 2012 9:28 pm ]
Thank you so much.
BUt that mean I can't use other light meters with Einstein/B800 ???
Author:  Technical Support [ Fri Oct 12, 2012 7:30 am ]
The Sekonic flash meter operates on a different frequency than the CC. However, you can connect the CST to the pc contact of say a L-358. This will allow the Sekonic to trigger any CyberSync receivers.
Author:  Technical Support [ Fri Oct 12, 2012 11:27 am ]
To expound a little further, the module available for Sekonic is a PocketWizard product, and is only compatible with PocketWizard products. Sekonic and PocketWizard are both distributed by MAC Group. There is not a module for Sekonic meters compatible with CyberSync or any other remote system (to my knowledge).
Author:  DukePro [ Sat Oct 13, 2012 2:01 am ]
Clear now... Thanks so much :)
Author:  Dave Jr [ Mon Oct 29, 2012 11:07 am ]
You can use the flash (delay) setting on your Sekonic, then use the CC to trigger the strobe. I'm not sure why you would need to do this for general use, but it can be useful for setting speedlites when using them with the strobes.
