Mon Oct 22, 2012 10:48 am
Hi,
i just got Eintein and tried to set up with my CC and CSRB+. It fire okae.. but i can't adjust power output of eintein from CC
i did follow instruction to sync studio light from open memory. it sync and a gray dot pop up under channel 13. However, when i tried to adjust power from CC, nothing happen.
help? did i miss some step?
Danny
Mon Oct 22, 2012 11:05 am
Einstein and CSRB+ or CSR+ cannot communicate with each other beyond triggering. The CSRB+'s output for power control is via a telephone cord connection, which the Einstein lacks, but our other lights have. For power adjustment with Einstein, you will need a CSXCV transceiver: http://www.paulcbuff.com/csxcv.php
Mon Oct 22, 2012 11:24 am
thanks for quick respond.
does your AB800 ab1600 work with csrb+ and CC? i meant, can CC remote control power the AB
thanks
Mon Oct 22, 2012 12:05 pm
Yes, all of our lights can work with the CSR+ or CSRB+ remotes, except the Einstein (which has its own receiver), and the old 5000's and 1000's.
Users browsing this forum: Google [Bot] and 17 guests
