| gray smoke http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3757 |
| Author: | dexter971 [ Thu Oct 25, 2012 11:06 pm ] |
| Post subject: | gray smoke |
hello, I recently ordered two flahs AB400. I made a small mistake in connecting the two AB400 on a 110V 220V Vagabond II. I did not realize it right away. one of them alone is triggered when you pressed "test" to 1/32 1/16 1/8 power. may from time after gray smoke coming out of the box. I unplugged immediately. I have not retested? I ordered a Vagabond II 110V. Do you think it is seriously damaged? |
| Author: | Technical Support [ Sat Oct 27, 2012 12:19 am ] |
| Post subject: | Re: gray smoke |
All Vagabond II's (orange bag) are 110V output, though they can accept 110-240VAC in for charging. If you have 110V lights. Regardless, if somethiing is emitting smoke, it will need to be serviced. |
