| White lightning recycle times at reduced powers http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3758 |
| Author: | Jakefreese [ Fri Oct 26, 2012 4:59 am ] |
| Post subject: | White lightning recycle times at reduced powers |
What are they? Is is possible to have them dialed down to get a couple or three frames in a row? Thanks! |
| Author: | Technical Support [ Sat Oct 27, 2012 12:26 am ] |
| Post subject: | Re: White lightning recycle times at reduced powers |
Recycle times will decrease with a reduction of power. It may not be an exact porportional reduction, especially at low power, but it is possible. Note, the flash durations do get longer at lower power. If youb are using the x1600, x2400, or x3200 use the blue 1/4 ppower switch to lower power, as this will reduce recyle by 1/4 and reduce flash duration and maintain color temperature vs. using the slider. |
