| How to use cyber commander as flash meter http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3759 |
| Author: | ravisrajan [ Fri Oct 26, 2012 3:49 pm ] |
| Post subject: | How to use cyber commander as flash meter |
Hello, I am unable to find a solution for how to use cyber commander as regular flash mater. I do not have any issue getting meter reading while using CC with Einstein where as I could not able to use CC as flash meter to get meter reading for flash/speed light. I wanted to use my current speed light as hair light/background light etc., Advance thanks for your help. Ravi S |
| Author: | Technical Support [ Sat Oct 27, 2012 12:35 am ] |
| Post subject: | Re: How to use cyber commander as flash meter |
Cyber Commander will only meter the light that is present when the meter button is activated. This would always be ambient and properly set up lights with CSR+, CSRB+, or CSXCV recievers. You cannot "arm" the Cyber Commander and have it wait for a manually triggered flash. If the speedlite was connected to a CSRB+ reciever, you can meter the light with the Cyber Commander in the same manner as the E640. |
| Author: | kenyee [ Mon Oct 29, 2012 2:51 pm ] |
ravisrajan wrote: able to use CC as flash meter to get meter reading for flash/speed light. I wanted to use my current speed light as hair light/background light etc. Buy a CSRB+ and connect it to your speedlight... |
