| LS3900 vs. TS13AC http://paulcbuff-techforum.com/viewtopic.php?f=8&t=376 |
| Author: | josh.hofer [ Tue Mar 16, 2010 12:03 pm ] |
| Post subject: | LS3900 vs. TS13AC |
Looking for some advice/tips on the real difference between the LS3900 & TS13AC! I plan on attaching a boom on whatever stand I end up with and using it with a 22HOBD/FOB47. What is the clear advantage on getting the TS13AC vs. LS3900? Thanks for any tips/advice :D |
| Author: | Technical Support [ Tue Mar 16, 2010 12:32 pm ] |
| Post subject: | Re: LS3900 vs. TS13AC |
The AC version has a shock absorber type pneumatic dampener. This means you will have a slower descension with heavy loads, like booms. Since no lunch is free, you also have to overcome that same resistance on the way up. Otherwise, among our stands, the AC and non-AC are virtually identical. |
| Author: | josh.hofer [ Tue Mar 16, 2010 1:26 pm ] |
Awesome, TS13AC it is then! Thanks. |
