Fri Oct 26, 2012 3:49 pm
Hello,
I am unable to find a solution for how to use cyber commander as regular flash mater. I do not have any issue getting meter reading while using CC with Einstein where as I could not able to use CC as flash meter to get meter reading for flash/speed light. I wanted to use my current speed light as hair light/background light etc.,
Advance thanks for your help.
Ravi S
Sat Oct 27, 2012 12:35 am
Cyber Commander will only meter the light that is present when the meter button is activated. This would always be ambient and properly set up lights with CSR+, CSRB+, or CSXCV recievers. You cannot "arm" the Cyber Commander and have it wait for a manually triggered flash. If the speedlite was connected to a
CSRB+ reciever, you can meter the light with the Cyber Commander in the same manner as the E640.
Mon Oct 29, 2012 2:51 pm
Buy a CSRB+ and connect it to your speedlight...
Users browsing this forum: Google [Bot] and 31 guests
