CSRB+s on multiple frequencies with Cyber Commander?
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3768
Author:  JimQ [ Mon Oct 29, 2012 8:12 pm ]
Post subject:  CSRB+s on multiple frequencies with Cyber Commander?
I have a setup with 4 different photographers all using CyberSync Trigger Transmitters, so they must be on different frequencies. They are triggering CSRB+s which are attached to Ab1600s. Each has at least one hair light, it’s inconvenient to raise & lower them for a setting change, so I want to adjust them with my Cyber Commander as necessary.
When I setup the Cyber Commander to do this, I found that all the CSRB+s must be set to the same frequency in order to have them all appear on screen together. I figured a workaround temporally, by going into the menu on the Cyber Commander and changing the frequency each time I want to make an adjustment to a particular light, but it’s an extra step I’d like to avoid if possible.
Any way for the Cyber Commander to remember that each light has it’s own frequency so I don’t have to change the frequency each time I want to make an adjustment?
Thanks
Jim
Author:  Technical Support [ Tue Oct 30, 2012 10:42 am ]
Post subject:  Re: CSRB+s on multiple frequencies with Cyber Commander?
No. The Cyber Commander was envisioned as a one set up/ one device concept. There is not a way to program different channels as different frequencies.
