| Can the Cyber Commander meter in 1/3 stops? http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3776 |
| Author: | echantigny [ Wed Nov 07, 2012 3:01 pm ] |
| Post subject: | Can the Cyber Commander meter in 1/3 stops? |
Hi, I've been wondering if there's a way to change the metering of the CC from full stops to 1/3 stops, like you can do on the Pocket Wizard? Thanks |
| Author: | Technical Support [ Wed Nov 07, 2012 3:12 pm ] |
| Post subject: | Re: Can the Cyber Commander meter in 1/3 stops? |
The Cyber Commander does not currently adjust 1/3 stops in any parameter. If the aperture reads xx' 3, that is 1/3 of a stop higher than the whole stop displayed, or one click on your aperture dial. The same holds true with xx' 6 or xx' 7, in that it is 2/3 of a stop, or two clicks. While some rounding will be done, you will be within a half of a tenth of a stop, where as a 1/3 stop increment would round to within 1.5 tenths. |
| Author: | echantigny [ Wed Nov 07, 2012 3:21 pm ] |
Alright. I already knew about the 1/10 stops, but I'm a bit worried about the limited adjustments on the shutter speed while working outdoors. 125 to 250 is quite a jump and my camera syncs at 200 so I'm stuck at 125 to have proper readings or do the maths myself. It's obviously not a big deal in studio since ambiant should not be an issue most of the time. Is there a plan to update the firmware for this? |
| Author: | Technical Support [ Wed Nov 07, 2012 4:12 pm ] |
We are exploring it, but no promises of when or if at this time. |
| Author: | echantigny [ Thu Nov 08, 2012 8:19 am ] |
Technical Support wrote: We are exploring it, but no promises of when or if at this time. Fair enough! :) Thanks |
| Author: | ricksieminski [ Thu Mar 21, 2013 10:52 am ] |
Any word on the shutter speed adjustment update? Do you think it'll ever happen? |
| Author: | echantigny [ Thu Mar 21, 2013 11:53 am ] |
Glad to see I'm not the only one worried about this. I do have to say that I'm really in love with the tool and if we can get passed this little issue, it would be amazing! |
| Author: | Technical Support [ Thu Mar 21, 2013 1:31 pm ] |
We are working on firmware updates. This has not been forgotten, but I do not have a time frame, nor can I absolutely confirm that it will happen. |
| Author: | rick2906 [ Thu Nov 20, 2014 7:22 pm ] |
Any updates ? I love the power commander but hate to do guesswork ! My camera base iso is 64. I can't even select it. |
| Author: | Technical Support [ Fri Nov 21, 2014 10:53 am ] |
There is currently no update to the firmware regarding 1/3 stop settings. However, you can adjust the Cyber Commander to ISO100 and CAL -.3f to equal the ISO 64 setting. This works because ISO is a global setting and affects ambient and flash equally. |
