ABR800 Ring Flash Cooling Fan
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3786
Author:  slippin2darknezz [ Tue Nov 13, 2012 6:10 am ]
Post subject:  ABR800 Ring Flash Cooling Fan
I just received my new ring flash and it works great, however a few times during shooting I notice the cooling fan comes on and it sounds like it is striking something inside the unit as it spins. If I touch the plug connector it seems to quite it down but as I an switching from horizontal to vertical position with the camera it will start again. It doesnt happen all the time, but when it does it quite disturbing. I have not used it since the last episode. Any suggestions?
Author:  Technical Support [ Tue Nov 13, 2012 12:23 pm ]
Post subject:  Re: ABR800 Ring Flash Cooling Fan
Contact customer service for a warranty resolution. We should be able to make it painless, but there is not anything the end user should do to correct it internally.
Author:  slippin2darknezz [ Wed Nov 14, 2012 6:18 am ]
I will give then a call today.
