Sun Dec 09, 2012 9:52 am
Hi,
I have some questions regarding the softbox grids. I've used the search function, but didn't find the info in the results.
1. What is the actual outer dimension for the nominal 24"x36" grid (G2436)? I have existing 24"x36" softboxes, but the actual length of the edges are smaller than the nominal size, so I wanted to make sure that the Paul Buff grids would fit.
2. Do the Paul Buff softbox grids have the rough "hook" part of the velcro? (i.e. the softbox inner lip is expected to have the fuzzy "loop" part)?
3. What are the dimensions (face size, depth) of the cells in the grid? I ask because different manufacturers seem to have different dimensions for a nominal beam angle (40 degree), and this affects the fall-off of the light. For example, lighttools 40 degree grids have 1.7" square by 2" deep cells.
Any information you can provide would be greatly appreciated. Thanks.
Mon Dec 10, 2012 12:48 pm
Size of the grid is 22.5" by 34.5" with a cell size is 2"x2" by 1-3/4" deep. Hook side is on the grid.
Tue Dec 11, 2012 12:57 am
Thanks for the info!
