| Will Vagabond Mini Work With Old WL10,000 White Lightning? http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3839 |
| Author: | Planet [ Sun Dec 23, 2012 3:18 pm ] |
| Post subject: | Will Vagabond Mini Work With Old WL10,000 White Lightning? |
Hi there: Will the old White Lightning WL10,000 and WL5,000 be ok to use with the Vagabond Mini Lithium battery packs??? Also, if I use TWO WL10,000 and ONE WL5,000 at full power (about 625WS total) would I get the same number of shots per charge as about One Einstein (more or less)? And finally, can I plug an extension strip into the Vagabond Mini Lithium so that I can use THREE lights at a time (since the VML seems to only have TWO outlets)? Thanks in advance. |
| Author: | Technical Support [ Mon Dec 24, 2012 3:53 pm ] |
| Post subject: | Re: Will Vagabond Mini Work With Old WL10,000 White Lightning? |
Yes, they lights are compatible, and you should get about the same number of shots or a little less. There is no problem using a splitter of any sort on the VML as you would a regular AC outlet. |
| Author: | Planet [ Mon Dec 24, 2012 4:09 pm ] |
Thank You!!! and thank you for taking the time to reply on Christmas Eve. :) Merry Christmas, Happy Holidays, and a Happy New Year. |
