| Cyber Commander won't trigger Canon 430EX via CSRB+ http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3846 |
| Author: | dchen99 [ Sat Dec 29, 2012 4:44 pm ] |
| Post subject: | Cyber Commander won't trigger Canon 430EX via CSRB+ |
I can use a CST to trigger the same setup so I know there is no connection issue. My Commander is also in full functional mode (same Frequency) to trigger my Einsteins just fine. I just want to add a Canon 430EX II to my strobe setup. So my question is, can Commander trigger both Einsteins set and a 430EX II (connected to a CSRB+ via 3.5mm sync cord)? Thanks. |
| Author: | Technical Support [ Sat Dec 29, 2012 11:37 pm ] |
| Post subject: | Re: Cyber Commander won't trigger Canon 430EX via CSRB+ |
Yes, but it needs to be defined as a speedlite and power set to on (both in the CC). This is covered in the new CC manual on pgs 30-33. http://www.paulcbuff.com/manuals/cc.pdf Also, remote settings on the flash need to be turned off, otherwise the hotshoe will be disengaged. |
