| Zeus help http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3850 |
| Author: | 10boxstudio [ Wed Jan 02, 2013 12:15 pm ] |
| Post subject: | Zeus help |
I am wanting to purchase (2) Zeus 2500 packs for an overhead application. Does anyone have a good way to hang a Zeus pack? In the past I've used the handles on other brands, but with the clam shell design I'm lost as to ideas. |
| Author: | Technical Support [ Thu Jan 03, 2013 5:08 pm ] |
| Post subject: | Re: Zeus help |
The Zeus system was designed with the idea the pack would remain on the floor, and leaving only a small head in the air. While I cannot offer any suggestions on how to suspend it, be sure you are not blocking any ventilation holes when you do so (i.e. don't put it in a bag or box of any sort). What is the reason they need to be suspended? If it is a matter of cord length, then extension cords should work. We no longer offer them, but Dynalite cords should work, as the systems are inter-compatible. |
| Author: | Chico [ Mon Jan 07, 2013 1:50 pm ] |
Technical Support wrote: The Zeus system was designed with the idea the pack would remain on the floor, and leaving only a small head in the air. While I cannot offer any suggestions on how to suspend it, be sure you are not blocking any ventilation holes when you do so (i.e. don't put it in a bag or box of any sort). What is the reason they need to be suspended? If it is a matter of cord length, then extension cords should work. We no longer offer them, but Dynalite cords should work, as the systems are inter-compatible. Which Dynalite cord do you recommend using if you want a longer cord/extension? They offer a few different ones. |
| Author: | Technical Support [ Mon Jan 07, 2013 3:12 pm ] |
Since this is a different brand, we cannot offer a "recommendation" or make any warranty, but the ones compatible with the M2000 series packs should work. |
| Author: | Chico [ Mon Jan 07, 2013 3:20 pm ] |
Technical Support wrote: Since this is a different brand, we cannot offer a "recommendation" or make any warranty, but the ones compatible with the M2000 series packs should work. How come you guys don't offer anything like this? |
| Author: | Technical Support [ Mon Jan 07, 2013 5:16 pm ] |
We did, but the sales were not there to justify carrying them. |
| Author: | Chico [ Fri Feb 08, 2013 6:14 pm ] |
Will this one work? http://www.bhphotovideo.com/c/product/1 ... Flash.html |
| Author: | Chico [ Mon Feb 11, 2013 12:24 pm ] |
Chico wrote: Will this one work? http://www.bhphotovideo.com/c/product/1 ... Flash.html anybody? |
| Author: | 10boxstudio [ Mon Feb 11, 2013 12:27 pm ] |
Yes that will work. |
