Einstein Stopped Syncing with Nikon
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3853
Author:  Arch Stanton [ Fri Jan 04, 2013 11:03 pm ]
Post subject:  Einstein Stopped Syncing with Nikon
Greetings:
Loving my Einstein, have used it several times with no problems.
But today, all of a sudden it stopped working via Optical Slave. My SB800
is triggering the Einstein but just not syncing, although it works perfectly with the sync cable. Shutter speed is well below 250s.
My setup is:
TT5 on SB800
MiniTT1 on D300
Einstein Optical Slave (PW MC2 on its way)
Also checked PW, and the FW is up to date.
Ill have my hand ready to slap me silly when it turns out to
be something simple!
Author:  Technical Support [ Sat Jan 05, 2013 12:21 am ]
Post subject:  Re: Einstein Stopped Syncing with Nikon
Probably due to the preflash of the Sb800. It may have previously worked due to manually setting the SB, or if the einstein was at a low enough power, it may have been able to fire twice, the second time in sync. At a higher power it may not have had time to recycle.
Or....the slave eye is off.
Author:  Arch Stanton [ Tue Jan 08, 2013 10:12 pm ]
Thank you it was an issue with the SB800, works great now.
Thanks again
