Mon Jan 07, 2013 2:30 pm
Have an issue with a B800 only firing on max power. Doesn't matter if the power bar is full power or turned all the way down, it still fires at the same level.
Any ideas on what could be causing this?
Mon Jan 07, 2013 3:10 pm
Do you have anything plugged into the telephone style remote port? If so, unplug that and see if there is any change. Otherwise, the slider is probably faulty, which would require the light to come in.
Mon Jan 07, 2013 3:27 pm
Nope, everythings unplugged. I'll ship it in to you guys then.
Thanks for the help.
Users browsing this forum: No registered users and 22 guests
