Issue with B800
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3861
Author:  Marlfox [ Mon Jan 07, 2013 2:30 pm ]
Post subject:  Issue with B800
Have an issue with a B800 only firing on max power. Doesn't matter if the power bar is full power or turned all the way down, it still fires at the same level.
Any ideas on what could be causing this?
Author:  Technical Support [ Mon Jan 07, 2013 3:10 pm ]
Post subject:  Re: Issue with B800
Do you have anything plugged into the telephone style remote port? If so, unplug that and see if there is any change. Otherwise, the slider is probably faulty, which would require the light to come in.
Author:  Marlfox [ Mon Jan 07, 2013 3:27 pm ]
Nope, everythings unplugged. I'll ship it in to you guys then.
Thanks for the help.
