| Trigger Voltage of White Lightning Ultra / WL10,00 Series Qu http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3896 |
| Author: | Planet [ Sun Feb 03, 2013 7:23 am ] |
| Post subject: | Trigger Voltage of White Lightning Ultra / WL10,00 Series Qu |
Hi again, Tech Support: I am using some inexpensive wireless remote triggers for my White Lightning WL10Kseries lights. They appear to be 12 Volt triggers (at least for the hotshoe). They have a 1/8th inch sync out, which I plug into a 1/4 inch adapter and plug into the back of my WL10K lights. I am not 100% sure what the voltage is when using the 1/8th sync out on the trigger, but is it likely that I would damage my lights using this trigger? (The triggers run on a pair of AA batteries.) And would you have any guess if I might damage my trigger? And finally, can you tell me the trigger voltages of the White Lightning Ultra series lights as well? I hope to pick up a used one or two. Thanks in advance. |
| Author: | Technical Support [ Mon Feb 04, 2013 10:30 am ] |
| Post subject: | Re: Trigger Voltage of White Lightning Ultra / WL10,00 Series Qu |
Early 5 and 10K's with no reset or with a red reset button had 120V sync voltage. Later ones with a black or green reset had 24V sync voltages. The Ultras had <9V sync voltage. The remotes will not damage the lights. However, if the sync voltage of a light is too high, it could feasibly damage the receiver, or the receiver would not work at all. |
| Author: | Planet [ Mon Feb 04, 2013 10:48 am ] |
Thank you. I am pretty sure that my WL10K have the green reset button. It is a relief to know that the lights won't be damaged by the receivers. |
