Sun Feb 10, 2013 4:24 am
Hi guys,
I had a few mis fires using my CST transmitter to fire my Einsteins (E640's have CSXCV's). I had the frequency set to 3, very close range with the range being no more then 15 ft away. I switched of the optical firing as another photographer was using a on board flash. Usually I leave optical on.
One out of the 3 lights would fire then sometimes 2 would fire. I tested the battery and it is reading 3.03 volts. When I put the battery back in the red light flashed 3 times. I changed the battery and the new battery reads 3.2 volts. The red light only flashes 2 times when I put it back in.
Any idea what could be going on?
Thanks guys..
Sun Feb 10, 2013 3:01 pm
The flashing as you put the battery in is just a confirmation that it reads the battery, though I have never seen it to be other than three blinks. The three blinks for a low battery indicator would be from a trigger episode (sync cord, test button, hotshoe).
Did you try changing frequencies?
Sun Feb 10, 2013 3:25 pm
Could it be possible that the frequency I was using was getting interference from something?
I didn't change the frequency on that shoot but I have changed it to 1 when I got home. I have another couple of shoots this week so I will see what happens then.
Sun Feb 10, 2013 6:40 pm
Did some testing this morning at home and I can't get the problem to replicate. Has to be some frequency interference where I was shooting yesterday...hopefully that's what it was.?
I use to have the same problem with Cactus 4's sometimes in different locations...thought I would had got away from that with these units..
Mon Feb 11, 2013 10:11 am
Interference is rare with CyberSync, but will be possible with any radio system in any application. Switching frequencies by several steps should resolve the issue.
Mon Feb 11, 2013 4:28 pm
Rare alright...I haven't had a mis fire in the 4,000 odd clicks I have used them for in the last couple of months....until now.
Thanks Tech Support...I will give that a go.
