Problem with Cybercommander Einstein update
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3910
Author:  sdegan [ Sun Feb 10, 2013 12:53 pm ]
Post subject:  Problem with Cybercommander Einstein update
Hi All,
I have updated the Einsteins to v31 and the CC to v40.
The problem I have is that every time I power the lights on and off the lights do not keep the 'Ready Beep' ON and all of them reset to Channel 1. Even if I use the the Light Settings in CC and power them off.
I tried to set the functions on the lights to those parameters but without success.
Am I missing something?
Author:  Technical Support [ Sun Feb 10, 2013 2:52 pm ]
Post subject:  Re: Problem with Cybercommander Einstein update
Have you removed the MicroSD cards from the lights? If not, then they are probably doing the firmware boot every time they get power.
Otherwise, remember to make changes from the Cyber Commander, otherwise changes to the head will be overridden by the Cyber Commander's settings.
If you do change the settings on the head, you can reopen that light in the OPEN MEMORY screen, and the changes will be brought into the Cyber Commander.
Author:  sdegan [ Thu Feb 14, 2013 9:08 pm ]
Hi,
The units are working with the new update, thanks.
The thing I have notices is that when I take a reading individually e.g. 'light one' or 'light two' etc. all the units fires. I remember that this was not happening before. Only when I set the global reading to ALL the all light were firing.
Am I right?
Is there a setting I have to use to get only the light I want the reading from to fire.
Author:  kenyee [ Thu Feb 14, 2013 10:29 pm ]
Did you turn off the optical slave sensor? ;)
Probably got reset w/the update...
Author:  sdegan [ Fri Feb 15, 2013 8:02 am ]
Many thanks, I missed that.
