Sun Mar 21, 2010 12:23 pm
How do I tighten the Stand Mount? I am able to turn the lever all the way around and I cannot keep the light from slowly sagging down during a shoot. TIA
Michelle
Sun Mar 21, 2010 3:29 pm
This might be a silly question, but have you made sure your light is all the way on the stand? The reason why I'm asking is because mine weren't, and it caused the light to lower as well.
Sun Mar 21, 2010 3:48 pm
Which light is it?
Sun Mar 21, 2010 6:46 pm
AB800.
Yes it is on all the way. The knob to tighten it is loose. It spins completely around.
Mon Mar 22, 2010 10:02 am
Just to clarify, are you talking about the longer lever handle that adjusts the tilt of the light? If so, it tightens clockwise, and loosens counter clockwise. If you hit the housing of the light before it tightens fully, pull out on the handle (perpendicular to the flash). This disengages the ratchet mechanism, and allows you to reposition the handle, neither tightening or loosening. Once repositined, let the handle reseat, then continue tightening.
Mon Mar 22, 2010 6:47 pm
That worked. Thank you!
Users browsing this forum: Majestic-12 [Bot] and 15 guests
