| Is it possible to split RJ11 from csr+ to two AB's http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3949 |
| Author: | erichard [ Fri Mar 08, 2013 11:12 pm ] |
| Post subject: | Is it possible to split RJ11 from csr+ to two AB's |
Can you use one csr+ or csrb+ to control two AB800's using the RJ11 jack and a splitter to control power levels via the Cybercommander. I was hoping I could control the 2 background lights with one receiver since they'd always have the same level assigned to them. I realize it's possible to get them to fire simultaneously in other ways, but I'm particularly asking about controlling their levels. |
| Author: | Technical Support [ Fri Mar 08, 2013 11:17 pm ] |
| Post subject: | Re: Is it possible to split RJ11 from csr+ to two AB's |
Yes, you can. They will maintain the same relative power. |
| Author: | erichard [ Fri Mar 08, 2013 11:26 pm ] |
Good to know and a very helpful feature. Thanks for the extra speedy response, Richard (BTW, while I was trying to update the firmware on my Einstein tonight, the microSD card slipped into the unit accidentally right where the normal insertion slot is. I just mention it, as you may want to improve that design slightly in the future to make this impossible. I got it out, but it took a while. I know I was supposed to insert it at 90 degrees, but I was half watching a movie when doing it). |
