| UV coated or not? http://paulcbuff-techforum.com/viewtopic.php?f=8&t=395 |
| Author: | photopat [ Mon Mar 22, 2010 7:46 am ] |
| Post subject: | UV coated or not? |
I've bought some used Ultra 1200 that have the banana plug type flash tube. I would like to order some spare tubes. However I do not know if the one I have already are UV coated or not. How can I check which model I have? In the long run I would like to have all my tubes UV coated, but will a mismatch between the UV and non UV coated tubes will bring an important color cast? |
| Author: | Technical Support [ Mon Mar 22, 2010 11:24 am ] |
| Post subject: | Re: UV coated or not? |
They were originally shipped with non coated tubes. If you lay them on a piece of white paper, you can clearly see a yellow cast if they are UV coated. The Ultra UV coated tubes are 5200K balanced, while the not coated ones are 5600K. If mixed, 5600K would yield a bluer cast than 5200K. |
| Author: | Luap [ Mon Mar 22, 2010 11:29 am ] |
All current Buff tubes for WLX. AB, Zeus and Einstein are UV coated and are 5600°K and match older non UV tubes that were also 5600°K. |
