| Sekonic 758 in conjunction with PCB transmitter and reciever http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3983 |
| Author: | stonehill [ Mon Mar 25, 2013 5:34 pm ] |
| Post subject: | Sekonic 758 in conjunction with PCB transmitter and reciever |
Hi guys I was just wondering if anybody has had experience using a sekonic light meters with Einstein lights and transmitters/receivers. Any help would be great Thanks |
| Author: | Technical Support [ Tue Mar 26, 2013 10:16 am ] |
| Post subject: | Re: Sekonic 758 in conjunction with PCB transmitter and reciever |
You can: A- connect the CST to the meter, and use the meter in corded mode (lightening bolt with a "C") just like you would straight to a flash unit. B-Set the meter to cordless mode (lightening bolt only). Press the meter button, which tells the meter to wait for a flash. Use the CST (or CC) in your other hand and press the test button. The meter will display a reading. Either of the above can be used in conjunction with the Cyber Commander acting as a trigger and/or wireless adjustment. Or it can be used with a simple CST. |
