| How even is the light along the face of the moon units? http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3994 |
| Author: | ricksieminski [ Mon Apr 01, 2013 8:15 am ] |
| Post subject: | How even is the light along the face of the moon units? |
Could someone post up images of the face of the 30", and 56" moon units and various apertures to show how even the light is across the face? |
| Author: | ricksieminski [ Tue Apr 02, 2013 9:13 am ] |
| Post subject: | Re: How even is the light along the face of the moon units? |
How about tech support. Has any of you done any uniformity lighting tests with the moon units? |
| Author: | Technical Support [ Tue Apr 02, 2013 3:53 pm ] |
On either, it is brighter just around the center opening and falls off some as you extend out to the edges. |
| Author: | ricksieminski [ Tue Apr 02, 2013 7:46 pm ] |
Thank you for your help, Technical Support wrote: On either, it is brighter just around the center opening and falls off some as you extend out to the edges. Falls off some? Any idea how much? 1 stop? 2 stops? More? |
| Author: | Technical Support [ Wed Apr 03, 2013 10:49 am ] |
The center ring of light is about 1.5-2 stops brighter than the rest of the moon unit, if measured at the fabric's surface. This ring extends about 3-4 inches from the center opening. |
| Author: | ricksieminski [ Wed Apr 03, 2013 10:51 am ] |
Thanks, you're the best! |
