| Disassembling Octa and Softboxes http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3995 |
| Author: | nofxrs [ Mon Apr 01, 2013 11:46 pm ] |
| Post subject: | Disassembling Octa and Softboxes |
Hi guys... i was wondering if there's anyway to disassemble the foldable Octo and Softboxes, removing the speedring, for an easier and not so heavy transportation? Thanks again |
| Author: | Technical Support [ Tue Apr 02, 2013 9:32 am ] |
| Post subject: | Re: Disassembling Octa and Softboxes |
Not really. The spokes are tied to the speed ring with a wire that is then twisted closed. While you can brute force it apart, getting it together would be more trouble than it is worth :) |
| Author: | nofxrs [ Tue Apr 02, 2013 11:25 am ] |
Technical Support wrote: Not really. The spokes are tied to the speed ring with a wire that is then twisted closed. While you can brute force it apart, getting it together would be more trouble than it is worth :) Thanks for that! Do you have any case suggestion to travel by air with your Softs and Octas?? |
| Author: | Technical Support [ Tue Apr 02, 2013 12:11 pm ] |
We don't have a specific recommendation, no. I don't think it would need Pellican type protection, but a firm sided case that they fit in should work. For the cost of many cases on the market, you may consider getting PLM's for travel work. These can collapse much smaller, and would give a softbox look when used with a diffusion fabric. |
