| What connectors are on the CyberSync™ Receiver Plus - CSRB+ http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4005 |
| Author: | ricksieminski [ Sat Apr 06, 2013 10:53 am ] |
| Post subject: | What connectors are on the CyberSync™ Receiver Plus - CSRB+ |
I want to hook this up to a speedlight, and would like to know what female connectors/jacks are on the CyberSync™ Receiver Plus - CSRB+ |
| Author: | kenyee [ Sat Apr 06, 2013 11:24 am ] |
| Post subject: | Re: What connectors are on the CyberSync™ Receiver Plus - CS |
rsieminski wrote: I want to hook this up to a speedlight, and would like to know what female connectors/jacks are on the CyberSync™ Receiver Plus - CSRB+ it's a 1/8" jack...they come w/ a PC sync port cable if your speedlight has that. Otherwise, you need a hotshoe w/ that kind of plug. |
| Author: | ricksieminski [ Sat Apr 06, 2013 11:52 am ] |
Perfect, thanks |
| Author: | ricksieminski [ Sat Apr 06, 2013 11:56 am ] |
Actually not so perfect, 2.5mm or 1/8th? |
| Author: | ricksieminski [ Sat Apr 06, 2013 11:59 am ] |
Ok, nevermind, it comes with an 1/8 to pc cable back to being perfect |
| Author: | Technical Support [ Sat Apr 06, 2013 12:00 pm ] |
The CSRB+ has a 1/8" female. It also has an RJ11, but you should not use that for a speed light. If your flash has a PC or 1/8 connection, cords are included to connect to the flash. If you need a 2.5mm cord, those are available here: http://www.paulcbuff.com/sccstaux.php If you need an adapter for the foot of your flash, you can use the one here: http://www.paulcbuff.com/slfa.php |
| Author: | ricksieminski [ Sat Apr 06, 2013 12:24 pm ] |
Thanks!! |
