Einstein fuses - do they blow often???
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4011
Author:  tr0910 [ Thu Apr 11, 2013 4:42 pm ]
Post subject:  Einstein fuses - do they blow often???
My Einstein had been sitting, and I turned it on, and it was on for 10 seconds then it shut off. Nothing would resurrect it, until I found the spare fuse that came with it. Now its working again.
This AB640 light is only 1 month old. Is this normal??? Can I just get standard replacement fuses??
Author:  Technical Support [ Thu Apr 11, 2013 5:00 pm ]
Post subject:  Re: Einstein fuses - do they blow often???
Fuses don't blow often, but it can happen and could be as simple as an out of spec fuse. If the fuse blows more than once in a short period of time, then there is an issue in the light which would require the unit to come in. If more fuses are necessary, I would suggest contacting us to ensure that replacing the fuse is the proper course of action, or if repair would be necessary.
