Thu Apr 11, 2013 4:42 pm
My Einstein had been sitting, and I turned it on, and it was on for 10 seconds then it shut off. Nothing would resurrect it, until I found the spare fuse that came with it. Now its working again.
This AB640 light is only 1 month old. Is this normal??? Can I just get standard replacement fuses??
Thu Apr 11, 2013 5:00 pm
Fuses don't blow often, but it can happen and could be as simple as an out of spec fuse. If the fuse blows more than once in a short period of time, then there is an issue in the light which would require the unit to come in. If more fuses are necessary, I would suggest contacting us to ensure that replacing the fuse is the proper course of action, or if repair would be necessary.
Users browsing this forum: Majestic-12 [Bot] and 29 guests
