 [ 13 posts ]
Sun Apr 14, 2013 6:23 pm
Hi Paulcbuff,
I just bought AB400 (used).
Is Pocket Wizard (Europe Version) compatible with AB 400?
There is test shoot :
please help.
best regards
bobgraha
Sun Apr 14, 2013 7:23 pm
Which pocket wizard model?
What happens if you use a regular sync cord?
Mon Apr 15, 2013 9:04 am
Thank's for your atention.
I used PW mini TT1 and Flex TT5.
I had setting PW and the result is :
I used my PW + Visico, the result is :
Mon Apr 15, 2013 9:50 am
I apologize, but I am not sure if the issue has been resolved, or if the images were showing something else.
Mon Apr 15, 2013 9:52 am
Have you put in new batteries and reset all settings on the PW TT to defaults?
I think you posted on the AB Flickr group too...
Mon Apr 15, 2013 11:11 am
I can't use my PW+Alienbees at High Speed Sync
I can use my PW+ Visico at High Speed Sync.
what should i do ?
thank's
best regards
Mon Apr 15, 2013 11:13 am
yes, i use a new batery n reset PW to default setting.
i posted on the AB flickr, but i can't solve the problem.
please help ...
Mon Apr 15, 2013 11:19 am
This is normal. The flash duration of a B400 is 1/2000 t.1, which is incredibly short. HyperSync relies on a long flash duration in order to work properly. As flash duration gets longer as you power down the flash, you may get better results by reducing power.
For HyperSync questions, your best bet is to contact Pocket Wizard/LPA directly.
Mon Apr 15, 2013 6:08 pm
Hi,
if my AB is normal why there is like black screen in top of my foto
and if i use my visico no like black screen on my foto
speed is 1/800
Mon Apr 15, 2013 6:42 pm
viewtopic.php?f=8&t=66
viewtopic.php?f=8&t=67
These two threads will fully discuss this. But what you are seeing is the difference between a short flash duration vs. a longer flash duration. You do not specify which Visico you have, so I cannot give you a definitive difference, but it is flash duration related.
What is happening is the PW triggers the light, the shutter opens, the light completes its burn, then the shutter finishes its travel. The flash duration is shorter than the travel time of the shutter. This is very similar to the x-sync being exceeded, only the opposite.
Your visico can burn long enough for the shutter to completely finish its travel, and does not result in the black bar.
 [ 13 posts ]
