Thu May 09, 2013 2:37 pm
I have 2 of these and one has begun to blink "red" repeatedy. I have replaced the batteries with fresh ones and it still just blinks contantly and will not fire a flash. This unit is one year old and probably used less than 10 times. Any clues on how to fix? Thanks, Ron
Thu May 09, 2013 4:31 pm
First, remove the batteries and let it sit for some time. Overnight should be plenty of time, but give it at least 10 minutes. Re-install batteries. If the problem persists, change frequencies. If the problem persists, there is a problem with the unit, and we will need to fix this under warranty.
If the problem is solved by the batteries out, then there was a weird electronics issue that required a reset. (not likely)
If the problem was resolved by a frequency change, then there may be something being broadcast on that frequency by another CyberSync device. This would be especially true if the two receivers were not on the same frequency.
I gave an order to this, but it can be done in any order. And for giggles, try also removing the batteries from the other receiver during your tests.
Users browsing this forum: Google [Bot] and 25 guests
