| Einstiens with Cybersync CSXCV Transceiver & Sekonic L758DR http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4027 |
| Author: | JoeMcCulley [ Fri Apr 26, 2013 12:45 am ] |
| Post subject: | Einstiens with Cybersync CSXCV Transceiver & Sekonic L758DR |
Is the Sekonic L758DR compatible with the CSXCV Transceivers? I can not get it to fire the strobs any help would be great. Thanks |
| Author: | Technical Support [ Fri Apr 26, 2013 8:19 am ] |
| Post subject: | Re: Einstiens with Cybersync CSXCV Transceiver & Sekonic L75 |
The built in module of the sekonic is not compatible with the CSXCV. The module is a Pocket Wizard device, while CSXCV is a CyberSync device. They run on different frequencies and different encoding. You can connect a CST to virtually any flash meter and use the meter as though it was connected to a light. Or use the flashmeter in cordless mode and fire the flashes with a CST by using its test button. |
| Author: | JoeMcCulley [ Fri Apr 26, 2013 8:44 am ] |
Technical Support wrote: The built in module of the sekonic is not compatible with the CSXCV. The module is a Pocket Wizard device, while CSXCV is a CyberSync device. They run on different frequencies and different encoding. You can connect a CST to virtually any flash meter and use the meter as though it was connected to a light. Or use the flashmeter in cordless mode and fire the flashes with a CST by using its test button. Thanks that is what I thought. I will just use the cyber commanders meter for now. |
