PLM assembly issue
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=4038
Author:  jwboring [ Sat May 04, 2013 9:36 am ]
Post subject:  PLM assembly issue
Guys, I'm having trouble with the 86" PLM I just got. I have a smaller one and had no trouble with it so I know the process. My problem begins with #3 of the instructions. The thumb screw will not go through the hole all the way. It holds the shaft in place but then when I go to insert using the speedring mount, it doesn't hold, because it does not go through all 3 holes (well, technically, 2 holes plus the most outer hole that you screw it into). This is very strange in that I can insert the thumb screw through all 3 holes independently, trying one at a time.
Again, I have no issues with a smaller one. Any idea's?
Thanks,
Jeff
Author:  jwboring [ Sat May 04, 2013 12:20 pm ]
Post subject:  Re: PLM assembly issue
never mind. my wife figured it out :) it's a much tighter fix than the other one.
