Mon May 20, 2013 1:44 am
Hi,
Will there be an issue if I plug a 220v 50hz version of let's say an AB or Einstein to a 220v 60hz AC mains ? Anyone experience any malfunctions over time?
Thanks.
Mon May 20, 2013 12:22 pm
Either will work. You may notice a slight difference in recycle time. Or you may not :0) Otherwise, all else is the same.
Sat May 25, 2013 3:47 pm
As TS said, there will normally be about a 15% increase in recycle time when using a 60HZ flash unit on 50HZ power, Shouldn't be any other problems.
